Iron Track Zeige E8XTL Red 1:8 Scale ARTR 4WD Brushless Short Course Truggy RC Remote
https://www.nitrorcx.com/16c225-red-artr.html
Truggy racing has always been an exciting and popular class in the R/C racing world. Truggies combine the sheer high performance capabilities of a 1/8th scale buggy and merges that with a high performance truck body with a longer and wider track complemented with wider wheels and tires. The result is a machine that you can drive very aggressively which makes it simply one of the most enjoyable things you are ever likely to experience.
The 36mm x 74mm brushless motor and 80amp speed control system rip up the track with instant acceleration. Top speed is very impressive, as the powerful 2075kv motor takes full advantage of the optimized gearing of the Zeige. This Truggy is designed for performance, handling and blistering speed. Transferring all this power is achieved by the same reliable, high performance three differential, 4 wheel drive system as the other 1/8 scale Iron Track cars.
The suspension of the Zeige is optimized for Truggy racing featuring fully independent suspension front and rear. It allows the driver to adjust camber, toe, roll centers and many other tuning options to dial it in for the specific terrain its running on. The high volume big bore oil filled shock absorbers are also fully adjustable, allowing you to fine tune your dampening.
The Zeige enjoys all the benefits and convenience of electric power in one awesome, ready to race package. Electric 1/8th scale racing is becoming popular as it is faster, less complicated and more reliable than conventional Nitro powered counterparts. Simply charge your batteries, turn on you radio and start tearing up your local park or race track.
Tear it up with the ZEIGE from Iron Track!
The ZEIGE will not disappoint with its list of feature like:
Hardened ionized materials are used for all joints and wheel axles.
Ultra-tough, specially formulated plastic nylon materials are used
Large big bore shock absorbers for better handing
All hard ionized steel differential gears
High speed ball bearings as standard
All differential and suspension components are filled with high quality silicone oils.
4 wheel independent suspension system
CVD Driveshaft for the front wheels
Electronics:
3674 2075kv Motor
S8A 80amp Brushless ESC
9KG Metal Geared Servo
Specification:
Length: 549mm
Width: 405mm
Height: 205mm
Wheelbase: 369mm
Required to Run:
2-3 Li-po Charger
2-3 cell Li-po Battery
2 Channel Radio and Transmitter
Electronics:
3674 2075kv Motor
Specification:
Length: 549mm
Width: 405mm
Height: 205mm
Wheelbase: 369mm
Required to Run:
2-3 Li-po Charger
