Iron Track Spatha 1:10 Scale 4WD Electric Short Course Truck Ready to Run (Green) RC
https://www.nitrorcx.com/16c339-green-rtr-24g.html
The hot new 1/10 Scale Iron Track Spatha ready to run short course truck has loads of awesome features. The 2 in 1 electronic speed control and receiver unit pumps out 20amp continuous and 320amps of maximum burst current to the 550 brushed motor delivering ground pounding acceleration. All of this power induced by the included 7.2v Ni-Mh battery with charger included. Make no doubt that this ready to run radio control short course truck is hobby grade. The 2.4ghz radio allows precise proportional control of this powerful truck. The steering servo delivers more than 6 pounds of torque to steer this beast of a truck in the right direction. Transferring all this instant electric power to the all terrain tires is an efficient shaft driven 4 wheel drive system. The geared front and rear differentials driven by an aluminum center drive shaft ensure maximum traction and reliability in the roughest terrain. The oil filled shocks allow the suspension to soak up all the bumps and rough stuff you throw at it. A pre-cut and factory painted body permits you to get into instant action once you open the box and get everything charged. The Spatha delivers smooth handling and precise response for you to enjoy the thrill of radio control truck action. With the Spatha you are guaranteed to have hours of fun and excitement!
Spatha Short Course Truck Features:
Geared front and rear Differentials
Shaft Driven 4 Wheel Drive System
Pre-cut Pre-painted Body Shell
3kg/6.6lbs Torque Steering Servo
Brushed RC550 Motor
2.4ghz Transmitter
2 in 1 2.4ghz Waterproof Receiver and Electronic Speed Controller
7.2v Ni-Mh 2000mah Battery
Ni-Mh Battery Charger
Iron Track Spatha Specifications:
Length: 453mm
Width: 256mm
Height: 155mm
Wheelbase: 288mm
Required to Run:
Four AA Batteries for Transmitter
Brushed RC550 Motor
2.4ghz Transmitter
Length: 453mm
Width: 256mm
Height: 155mm
Wheelbase: 288mm
Required to Run:
