Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Exceed RC Support - Nitro Cars
Reload this Page >
Iron Track Electric Centro 1:18 4WD Truggy Ready to Run (Black) RC Remote Control Rad
Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
Old 04-26-2018, 11:51 AM
yadac123
Default Iron Track Electric Centro 1:18 4WD Truggy Ready to Run (Black) RC Remote Control Rad
https://www.nitrorcx.com/16c665-black-rtr-24g.html
Iron Track introduces its newest 1/18 scale Centro Truggy. This small scale truggy has all the key features of bigger 1/10th scale truggies such as shaft driven four wheel drive, durable differentials, oil filled shocks, and robust design. It's all packed into a truggy that will fit in the palm of your hand. The Centro is also fully equipped with a 2.4ghz radio system, powerful 370 brushed motor, 120amp burst rated speed controller, and a 7.2v 800mah Ni-Mh battery pack with battery charger included, so it's completely ready to run with the exception of adding AA batteries for the radio. The compact truggy chassis lets you take on other off-road vehicles in wheel-to-wheel action, allowing you transform your yard into a fun offroad course!
Electronics:
2.4ghz Transmitter
2 in 1 Electronics Speed Controller and 2.4ghz Receiver
7.2v 800mah Ni-Mh Battery
370 Brushed Motor
1.1kg Precision Steering Servo
Features:
Molded protective gear cover
Molded tub chassis with optimized weight distribution
4 oil-filled rebuildable shocks with progressive springs
Special titanium anodized shock caps
Fully independent double A-arm wishbone suspension
Tough C-hub steering knuckles
Tough and efficient 4WD shaft driven drive train
Low friction ball raced bearing
4 high-traction multi-block tires
Attractive 5 spoke wheels
Factory-finished pre-cut body
Front and rear molded bumpers
Twin point steering with integrated servo saver
Specifications:
Length: 255mm
Width: 187mm
Height: 88mm
Wheel Diameter: 66mm
Wheel Width: 33mm
Weight: 552g
Required to Run:
Four AA Batteries
