Mad Gear 1/16 Electric Short Course Truck 2.4ghz Ready to Run (Blue) RC Remote Contro
https://www.nitrorcx.com/72c-madgear...-blue-24g.html
Our Mad Gear short course truck now comes in a 1/16 size! It delivers big short course fun in a mini ready to fun package! The MadGear 1/16th Scale Short Course Truck is ready to conquer the dirt at your local track or favorite bashing spot. Turn your yard into a full on short course track! Featuring a 4 wheel drive drivetrain, adjustable suspension settings, and big bore oil filled shocks. Powered by an electric 380 brushed motor and a 7.2v 1100mah Ni-Mh battery this truck has enough power to power slide and drift around corners. Shock absorbing front and rear bumpers help protect the truck from minor collisions while the built in spring loaded servo saver will ensure the maximum life span from the pre-installed steering servo. Short course style rims and tires have also been included with this model to polish off the scale looks.
Specifications:
Motor Type: Electric Brushed RC 380 Motor
Drive System: 4 Wheel Drive
Length: 292.5mm
Width: 195.4mm
Height: 112.4mm
Wheelbase: 173.6mm Front and Rear
Tire Size: 64.3*30.6mm
Ground Clearance: 12.5mm
Shocks: Oil Filled Big Bore Shocks
Speed Control: ESC, Servo and Receiver - All in One Unit
Battery: 7.2V 1100mah Ni-Mh Battery w/ Charger
Radio System: 2Ch 2.4GHz Remote
Required to Run:
4 AA Batteries for Transmitter
Specifications:
Length: 292.5mm
Width: 195.4mm
Height: 112.4mm
Required to Run:
