Exceed Racing Electric Powered Fiberglass Catamaran 650mm Brushless Almost Ready to R
https://www.nitrorcx.com/99b-10117-650-ep-artr.html
Speed across the water with your RC High Performance NEW DESIGN RC BOAT! This extreme detailed 25" boat is powered by a high performance 2830-2185kv water-cooled brushless motor for super fast speeds and great maneuvering capabilities. Water cooling systems are implemented into the boats design to keep the boat engine cool when running in extreme conditions.
This boat has a huge amazing factor. Everybody who sees this 25" monster is literally blown away by the quality of its amazing paint work, even before you take the lid off to reveal the monster of a motor! Everything about this boat is simply stunning even before you put it in the water. It is constructed by hand using light weight and super strong epoxy resin Fiberglass Catamaran to increase speed and improve handling and stability, and then factory painted to the highest standard.
The boat comes complete with a strong plywood stand making starting easy. Equipped with the powerful 2830-2185kv water-cooled brushless motor, starting is as simple as pulling the cord. Measuring over 25 inches long and featuring a professional large torsion propeller and water-cooled engine, this RC boat is perfect for ponds, rivers, and lakes. Take this fully functional reproduction of an offshore boat out to the water and watch it cruise!
That is what everybody says as soon as they see this missile. This boat has been a huge success in races seen literally all over the world. It is jaw dropping good looking and has blown everything away in the water, and as fast as it looks with a race proven 2830-2185kv water-cooled brushless motor already installed. 90% ready to race right out of the box, all you have to do is installing servo, batteries, receiver, and transmitter to get it out cruising on the water.
Almost Ready To Race, requires batteries, receiver and transmitter
Specification:
Length: 650mm
Beam: 190mm
Height: 95mm
Weight: 1500g
Hull Type: Fiberglass catamaran
Motor: 2830-2185kv water-cooled brushless
Propeller: Carbon-reinforced plastic D32*P1.4 3-blade
Driveline: Flexible drive
Hardware: CNC aluminum strut and rudders
Radio (Required): 2 channel
Battery (Required): 11.1v 3000-4500mAh LiPo
Specification:
Length: 650mm
Beam: 190mm
Height: 95mm
Weight: 1500g
