UDI U001 Black Venom 2.4GHz High Speed RC Racing Boat
https://www.nitrorcx.com/28b-u001-black.html
The UDI U001 comes equipped with a water cooling system to prolong the life of the boat. Advanced 2.4GHz automatic code pairing technology allows you to control different boats use different frequencies. When the 2.4G Signal becomes weak, the transmitter will detects and flashes an out-of-range light. The self-righting feature lets you command your boat back into action if it capsizes. Bilateral navigation rudder design automatically corrects yaw. When the battery runs low, the transmitter will sound "di, di, di" this warns you about 1 minute left, so you can sail it back for retrieval.
Specifications:
Operating Frequency: 2.4 GHz
Transmitting Distance: (Outdoor And Unobstructed): 80 m
Speed: Up to 15mph
Weight: 322g
Battery: 3.7V×2 600mAh Li-FE Battery
Play Time: 6-8 minutes
Operating Temperature Range: 14° F~ 104° F
Product Size:
Length: (13.46 in) 342 mm
Height: (3.5 in )89 mm
Width: (3.46 in) 88 mm
Package Contents:
1×UDI001 RC Boat
1×Controller
1×3.7V×2 600mAh Li-FE Battery
1×USB Charger
1×Blades (1pcs/1 set)
1×User Manual
Specifications:
Speed: Up to 15mph
Weight: 322g
Product Size:
Package Contents:
1×UDI001 RC Boat
1×Controller
1×USB Charger
1×User Manual
