WL Toys V686G 5.8 FPV Headless Mode 4ch Quadcopter Drone with 2MP Camera w/Real-time
https://www.nitrorcx.com/28h-v686g-58gfpv-4gb.html
The WL Toys V686G 4CH 6-Axis Gyro FPV Wi-Fi Camera Cellphone Control RC Quadcopter supports cellphone control via Wi-Fi connection from up to 200ft away, offering a cool new way to pilot an RC quadcopter. While in headless mode there?s no need to adjust the position of aircraft before flying. One key return function makes it easy to find its way home. Equipped with a 6 axis gyro the quadcopter has strong stability in flight. Easy to implement various flight movements, stronger wind resistance, easier to control. The lightweight airframe is surprisingly durable. Adopted 2.4G technology for anti-interference, multiple copters can fly at the same time without interfering with each other. The attached 2MP camera delivers high definition, real-time images that allow you to have a clear view from the sky. The 8.5mm coreless motors provide optimal efficiency and power usage. The quadcopter is equipped with LED lights which make low light flying possible. Package includes a FPV monitor so you can watch real-time footage from the onboard camera.
Description:
Frequency: 2.4G
Channel: 4CH
Gyro: 6 axis
Flight Duration: 8 Minutes
Remote Control Distance: Within 400ft
Recharging Time: 90mins
Battery For Quadcopter: 3.7V 730 mAh(included)
Battery For Transmitter: 6 x AA Battery (not included)
Color: White
Product size: 7.8*7.8*3.6 INCHES
Function: ascend/descend/forward/backward/side flying/360?rolling action/hover/3D/LED/camera/5.8G transmission /One key return
Package includes:
1 x WL Toys V686 Quadcopter
1 x Transmitter
1 x 3.7V 730mAh Lipo Battery
1 x HD Camera
1x 4GB Memory Card
1 x FPV Monitor
1 x Antenna
1 x Card Reader
1 x Charger
4 x Protection cover
4 x Propeller
1 x Screwdriver
1 x English Manual
Description:
Frequency: 2.4G
Channel: 4CH
Gyro: 6 axis
Color: White
Package includes:
1 x Transmitter
1 x HD Camera
1x 4GB Memory Card
1 x FPV Monitor
1 x Antenna
1 x Card Reader
1 x Charger
4 x Propeller
1 x Screwdriver
1 x English Manual
