WL Toys V757 Shooting Bubble Master Co-Axial Metal 3.5 Channel Helicopter w/ Gyro (Gr
https://www.nitrorcx.com/28h-wlv-v757-bubble-green.html
The V757 Bubble Master is unique 3.5 channel co-axial helicopter. It has the ability to produce bubbles while flying via transmitter controlled button. It is also very stable thanks to its on board gyro. It is a 3.5 channel helicopter which means it can fly forwards, backwards, ascend, descend, rotate clockwise, and counter-clockwise. The bubble master is controlled through infra red signals. A push of a button activates the bubble machine mounted on the chopper and allows it to produce bubbles in flight. The V757 brings a whole new level of fun for helicopter flight. Make the house pets go wild with the bubble master!
Specifications:?
Size: 24 x 11.7 x 4.7cm (9.4 x 4.6 x 1.9 in)
Frequencies: Infra red bands: A, B, & C
Battery: 3.7V240mAh li-po battery;
Charging time: 45 minutes;
Flying time: 5-7 minutes;
Remote control distance: 10 meters
Package Includes:
WL V757 RC Helicopter
IR Transmitter
Pre-assembled helicopter
Bubble Water
USB Charger Cable
Tail Rotor x 2
Main Blade x 2
Water dropper for refilling
Instruction manual
Required to Fly:
Transmitter batteries: Six 1.5V (AA) batteries
Specifications:?
Package Includes:
IR Transmitter
Bubble Water
USB Charger Cable
Tail Rotor x 2
Main Blade x 2
Instruction manual
Required to Fly:
