Exceed RC Electric Powered Fiberglass Shark II Mono 1 Brushless Almost Ready to Run B
https://www.nitrorcx.com/99b-10036-650-ep-artr.html
The all new competition Shark II racing boat is here. The fiberglass mono 1 step bottom hull is handmade with FRP fiberglass and comes with a super smooth gel coat finish. It comes out of the box with the hull polished to a mirror like shine with streamline design.
This boat features an innovate anti-turnover design in the hull. It allows water to enter one side of the hull in the event of a turnover allowing the boat to naturally flip over right side up. The slots and holes in the hull are made for this feature.
The hull is super light weighing about 430grams without other hardware. The almost ready to run version comes equipped with a B2848-3300KV water cooled brushless motor with a 75 amp brushless electronic speed controller. A flex drive shaft transfers all the power to a carbon-reinforced 3.6x1.4 three bladed propeller and provides excellent speed. This boat is perfect for Mono competitions or tearing up ponds, rivers, lakes, and can pretty much any body of water.
Features:
Anti-turnover design
Suitable for Mono 1 competition
Flat surface bottom for high speed racing
Handmade
Ultra strength polyester fiberglass material
Strong and Light Weight
Streamline Design
Polished like mirror
Specifications:
Length: 600mm (23.62 inches)
Beam: 165mm (6.49 inches)
Height: 80mm (3.14 inches)
Weight: 1150g (40.56 oz)
Hull Type: Fiberglass Mono 1 Step Bottom
Propeller: Carbon-reinforced plastic D36*P1.4 3-blade
Driveline: Flex Drive
Hardware: CNC Aluminum Strut and Rudders
ESC: 75A
Motor: B2848-3300KV water-cooled brushless
Required to Run:
Radio (Required) 2 channel surface transmitter and receiver
Weight Added (Required) 60g lead(Pb) for Auto Stable System
Battery 7.4v 4500-5400mAh LiPo
Charger for Lipo
Features:
Handmade
Streamline Design
Specifications:
ESC: 75A
Required to Run:
Charger for Lipo
