Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
REPLACE 1SPEED W/ A 2 SPEED 4 INFINITY
Old 01-20-2008 | 12:50 PM
Default REPLACE 1SPEED W/ A 2 SPEED 4 INFINITY
Bad idea ,,, Thanks everybody for the info!!
Old 01-20-2008 | 12:53 PM
Macanan's Avatar
Default RE: REPLACE 1SPEED W/ A 2 SPEED 4 INFINITY
It is possible, but i wouldn't advise it, everyone will tell you to stay with a single speed, which I'm replacing my 2 speed buggy with single speed.
Old 01-20-2008 | 01:35 PM
leave it a single speed, i converted my tsunami to a single speed, i am much happier with it, off roads need single speed.
Old 01-21-2008 | 06:16 PM
Yes it's possible to replace it with 2 speed because exceed-rc ATV is 2 speed and you can get that transmission and it drops right in. Trucks are usually in single speed.
Old 01-21-2008 | 06:18 PM
you can get thepart here: http://www.exceedrc.com/sparepart51c814.html
ORIGINAL: tommybrickit
I was reading something about being able to replace the 1speed gearbox in my INFINITY with a 2 speed from REDCAT[>:] ha ha ha That would be AWESOME!!!! Can you imagine the top end? The quickness? Zowie!@#$% Well my brothers , is this possible? Has anybody done this yet? What has to be done? Please contact me personnally at [email protected] THANKS<THANKS and thanks for youw wisdom on this Tommy
Old 01-22-2008 | 10:35 PM
Thanks everybody! I appreciate the knowledge and know how.
Old 01-23-2008 | 03:28 AM
I would think it would mainly depend on what kinda power you have. My Revo is a 2 speed and i wouldnt have it any other way. Since i opened up my sons infinity and got it breathing alot better its hitting max speed to quickly. So we were thinking of going with a two speed. I was just wondering how close the ratio is with the tranny. Not to mention if the tranny holds up well.
Old 01-23-2008 | 07:56 AM
the second gear is too high, its not close like the traxxas gears.
Old 01-23-2008 | 02:41 PM
well that sucks. What kind of gearing do you recomend then? As far as the spur and clutch bell?
Old 01-23-2008 | 02:42 PM
And......is there anyway to modify the gears in the two speed? Im sure if there was a way to that someone would have done it....and you really seem to know your stuff ehroof. Thanks for the reply
Old 01-23-2008 | 02:55 PM
your welcome bro and thanks for the compliment. you can put an hpi 13/18 tooth clutch bell in it, you need to get a needle bearing and the bushing setup for it, its only a few buck for them and it will make the gearing lower and the 2 speed better, you can check my posts out on the redcat forum
http://www.rcuniverse.com/forum/m_5399029/tm.htm
Old 01-24-2008 | 03:23 AM
Cool. thanks for all the info
Old 01-24-2008 | 08:28 PM
Does the 12/18 CB make it better than the single speed?
Old 01-24-2008 | 09:13 PM
no, it just makes the 2 speed better in the truggy, stock its too high geared
Old 01-25-2008 | 12:31 PM
And how would it compare to the single speed?
Old 01-25-2008 | 01:18 PM
it doesnt, the single speed is all around better, low end, high end, its just a better setup on the 1/10 truggy if you ask me.
