help with Engine setting
I have a Xtreme Fire Yellow 2-Speed 4WD Nitro Gas Radio Remote Controlled RC Off-Road Buggy Car RTR
i would like to get back to break in settings,And would like to know if there is any way to replace silicon rubber pipe piece because it keeps breaking.And would that cause air bubbles in the feul line. Thanks
Highspeed needle...2.5 turns out. Lowspeed needle...flush with the collar.
you can order a new silicon deal from a redcat dealer, im not sure if nitrorcx has any or not. i havent got my exceed yet.
http://www.clermontmotorsports.com/s...e-*1PCS/Detail
And make sure your gas tank has a good seal and there are no holes in the fuel lines, unplug one of the lines and blow in it with your mouth and close the end of the other line and see if you can hear a leak. the exhaust i dont think would cause air bubbles.
Every time i get it running it runs good for about 30 sec.Then it wont start until i adjust all the needles.then it start all over again.anyone got any Ideas?
Your tube may have holes. Clean it and blow one end and block the other end.
get 51C00-02058 here:http://www.nitrorcx.com/sparepart51c22.html
Andy
Andy
