Exceed RC Support - Nitro Cars Discuss all Nitro Car Support for items purchased or will be purchasing at Exceed RC.
ESC Problem on sunfire
Old 03-16-2008 | 01:09 AM
Default ESC Problem on sunfire
I know this says nitro forum, but i bought a sunfire ep, and it ran fine the first 3 cycles then halfway through driving it with the 4th charge I stop the car then i go to accelerate and nothing....The light comes on on the esc when i pull the trigger but nothing to the motor, I checked all wires and its connected...one more thing the esc doesnt get the audible beep when its turned on anymore. is there anykind of warranty that covers it I got it from raidentech.com they take returns but it would probably be cheaper for me to buy an esc than to ship it back to them
Old 03-17-2008 | 06:15 PM
Default RE: ESC Problem on sunfire
Don't worry I can help. But do this this. disconnect every and try to connect it again. Run the battery down and charge it for a good 12 hours. See of this fix the problem.
Let me know your Raidentech order number
Andy
Old 03-17-2008 | 06:52 PM
Ya know the olny complaint I have on these buggies is this they eat batterys like no other! But my friend who has electric buggies says I need to get 4200mah batterys for the 4 wheel drives will eat the 1500mah batterys for lunch is this right or wrong?
Can you tell me is this right this question is directed to (yadac123)
Old 03-17-2008 | 09:05 PM
Yes the the stock battery won't last for sure if you got money you should get better battery and better charger. It would be the best thing to do.
Andy
Old 03-17-2008 | 10:06 PM
Andy thanks for the quick reply and I will spend the money on some good batterys!!
Mark
Old 06-29-2008 | 08:20 PM
hey,
this has happened to me before, you have to make the throttle to nothing, where the car is idle and the wheels arent moving, at the center. if you start the car with the throttle turned up or down, the car will not run. this happened to me w. my Traxxas stampede. its been 3 months since you last wrote but see if that caused the problem.
mark
