Another problem
TX
I haven't had a normal run from my Forza in months.It had tons of problems.Now when I press the throttle I have to wait for a few seconds for it to accelerate and the speed is very slow.I already replaced the servos and the receiver and I still have radio problems.
Are you sure its your radio? I think frozenshade is on the right path. Make sure that your lowspeed needle is flush with the collar, and your high speed needle is 3 /1/2 turns out from closed. Your idle screw should be set to allow the barrel in the carb to be 1mm open. Try this and let us know.
TX
Maybe part of the problem is the radio.When I turn the buggy on and then press the throttle the servo will sometimes respond after a few seconds.
ORIGINAL: cirec
so when you interchange the trottle and steering servo on the receiver the problem occured on your steering servo? the trottle servo when back to normal? if yes then it's a receiver problem.
Andy
Andy
ORIGINAL: cirec
I took it out and placed it back in and I still have the problem.
TX
A receiver problem?I haven't crashed the buggy when I used the aftermarket receiver so what could have happened?Maybe I bought a broken used receiver at my lhs.The receiver didn't come in a box.A person just found it and sold it to me.It was the only 27MHz AM reciever they had.I'll probably just buy a FM radio set because I heard that FM is better then AM.
