I NEED HELP!!!!!!
my exceed truck ran fine for the first 6 tanks but then when i started it on the 7th tank it went to full power on its own i have no idea what would cause this any tips would help thanks
NJ
If you are using the 4 "AA" battery holder as your receiver pack, that may have gone low on voltage and when that happens your throttle will go wide open. At that point you have no controll over the car. Plug it in and see how your steering is. If it's weak or not working at all, there's your problem. Install new batteries and see if the problem goes away. Are you running a failsafe? If not I would get one ASAP. It'll save you buggy and keep some green in your pocket.
Hey just got my new buggy ..its been doing the same since i got it. I have brand new batteries and i have played with the idle screw. It will start but if i touch the brakes it shuts off. cant figure it out..... Any help would be great!
