A little help with Exceed Sunfire RTR electric
Hello and thanks in advance.
My son just bought anxceed Sunfire RTR with an electric motor.
Unfortunately I've already had to replace both of the front lower suspension and straighten outa couple of bent parts because he can seem to keep from running into mailboxes and stop signs.
But that's not my current problem.
On the bottom of the PC board of the ESC is a large electrolytic capacitor soldered to two points.
That capacitor has broken its contacts from the board.
Fortunately I still have the capacitor. If someone could post a clear picture
of where that capacitor is solder I would greatly appreciate it.
EDIT: I forgot to mention the ESC model is the SP-03018
It is an electrolytic capacitor so it has negative and a positive leads. I know they are connected to two of the large wires...either from where the battery wires connect, or where they lead to the motor.
Soldering it will be simple, I just want to be sure of which points.
Thanks.
