RCU Forums
-   Exceed RC Support - Nitro Cars (https://www.rcuniverse.com/forum/exceed-rc-support-nitro-cars-472/)
-   -   HELP!! (https://www.rcuniverse.com/forum/exceed-rc-support-nitro-cars-472/6896007-help.html)
Steve1960 01-12-2008 04:11 PM
HELP!!
I need a dogbone for my monster truck. I ordered pn#08029 as per instruction manual. The dog bone in my truck 90mm and is thicker. The #08029 is only 87mm. Has any one ran in to this problem when ordering parts from Nitrorcx. Model#51c08 Infinity. Any ideas
{GBI}Harryball 01-12-2008 04:37 PM
RE: HELP!!
The redcat product is the same as your exceed, after checking there website www.redcatracing.com the part you ordered is the right one.
http://www.redcatracing.com/itemdeta...p?partno=08029
Steve1960 01-12-2008 04:39 PM
RE: HELP!!
Yes by Part number but the new one is 3mm shorter and thinner.
NitroKiller 01-12-2008 04:53 PM
RE: HELP!!
Just looked at the Nitrorcx website. The caption shows 88mm, but next to it shows 89.5mm for the item #08029. Could the .5 mm left over be taken up by the O rings? As to the thickness of the metal, maybe it was a manufacturer change?
Steve1960 01-12-2008 05:10 PM
RE: HELP!!
NitroKiller i measured the one i got from Nitrorcx its 87mm. 3mm shorter then the original i need 90mm
Steve1960 01-12-2008 05:13 PM
RE: HELP!!
You talk of o rings where? This is my firstNitro truck
Macanan 01-12-2008 05:22 PM
RE: HELP!!
In the cup that your dogbone set's in, look in there.....ok seee there is a little round rubber O ring, That is a O ring.
Plus you can not I repeat can NOT go by the parts book they gave you, I ran into the same thing and what they was calling for was way longer then what I needed, what I would do is go to the redcat forums and tell them what your looking for, and they will get you what you need. http://www.rcuniverse.com/forum/foru...smode_1/tt.htm
Steve1960 01-12-2008 05:25 PM
RE: HELP!!
no oring present where yuo stated
Macanan 01-12-2008 05:31 PM
RE: HELP!!
Then what you need to do is add some O rings and that will take up the slack give me a minute and ill post a picture of what im talking about
Steve1960 01-12-2008 05:33 PM
RE: HELP!!
Thank you that would help.
Macanan 01-12-2008 05:49 PM
RE: HELP!!
1 Attachment(s)
Ok here you go if you dont understand just ask.
Steve1960 01-12-2008 05:56 PM
RE: HELP!!
Ok put a piece of tubing in both sides where axle goes?
Steve1960 01-12-2008 05:58 PM
RE: HELP!!
Thanks for the help:D
Macanan 01-12-2008 06:01 PM
RE: HELP!!
Yeah but make sure it isnt to tight when you put it back together
