engine problem
In order for me to start up my buggy, I have to screw in the idle adjusting screw enough.After I screwed it in, the buggy accelerates a bit.I unscrewed it a bit but then the engine starts up and then turns off.What do I do?
RE: engine problem
In the carb the idle screw should allow a 1mm opening. You low speed needle should be flush with its collar and the high speed needle should be turned out about 3 1/2 turns. Hope this helps
RE: engine problem
3 1/2 is too much on the high needle, 2 1/2 is a good base setting on the vx
RE: engine problem
I adjusted the idle screw to where it allowed a 1mm opening but it won't start and I had the high speed needle turned out 2 1/2 turns.I can ony get it started with it accelerating.Is this because I might have broked the engine in wrong?
RE: engine problem
not sure but on my buggy the needle is out about 3 1/4 and i no im running a lil rich but not that much
RE: engine problem
ORIGINAL: ehroof 3 1/2 is too much on the high needle, 2 1/2 is a good base setting on the vx |
RE: engine problem
for me, 2 mm gap is better.
Andy |
RE: engine problem
Cirec, I think yadac is right on the gap. Make it 2mm and see if that helps. If you have to give it gas to start it.
| All times are GMT -8. The time now is 04:08 AM. |
