Fast plane for a TT Pro .36
Can anybody recommend a simple to construct, high-speed sport plane for a Thunder Tiger Pro .36? I've currently have it installed on a Gremlin and the engine is turning about 20k on an 8x7 prop but the Gremlin is prone to surface flutter(I got it at a garage sale).
Any recommendations appreciated!
Kit or ARF? The .36 is the hot rod engine for a .25 model and falls a little short on the .40 size models. You could build a Scat Cat rather light and inexpensively, or see if this ACE is still around.
https://www.rcgroups.com/forums/show...tern-Plane-Kit
I look for .25 models on a regular basis, hard to come by.
https://www.rcgroups.com/forums/show...el-tech-me-109
The World Models had an airplane called a Wingman II. It's a baby brother to the Sky Raider Mk II, at about 80% smaller in size. An internet search shows it out of stock, but if you could locate one, it would be a good match. It was primarily an electric airplane, but can be easily converted to glow. The larger Sky Raider Mk II would do about 90 mph on a Thunder Tigre Pro 40. I think the Wingman II on the TT 36 could do over 100 mph.
I looked for a .20 to .25 sized P51 Mustang kit with no luck
I looked for a Diamond Dust Delta kit with no luck
Here is a Shrike.......Lanier Shrike 40 Short Kit RC Airplane Kit | eBay
Your engine with a 9 x 7 or 8 x 8 prop should be lots of fun.
"It would be really easy to build up a slightly smaller Q500. Maybe 400 square inches. Foam cores, $40 worth of wood and a few micro servos. Make it V tail without rudder and landing gear and no more then 3 lbs. Could be 150mph capable".
I like this suggestion, if you are a builder? You could build a 75% Quickie with a 36" wingspan. My guess would be around 135 mph?
Well, I went to the Swap Meet held by the Kansas City Radio Control club this morning. Came across an older arf from a company called Super Kraft. The model is a small-ish version of an F3D pylon racer. The Pro .36 is a drop-in fit. I think this will get past 130 mph without too much trouble. I will report back when I get to it in the early Spring. It's called the F3D-30.
