Shrike 10--1st speed plane
Hi,
I just picked up my Shrike 10 kit--it will be my first actual speed plane.
My engine options are OS 15 (the little bushing R/C engine), OS 25 FSR or Webra 32 Speed.
My question: How fast with each engine? My fastest current model is an Aresti 40 with Rossi 53 with mini pipe. I can keep up with it, no problem, but not sure about the Shrike with anything more than the little .15.
Any advice will be appreciated; well, most advice, anyway!
TX
RE: Shrike 10--1st speed plane
Jim,
I would think that the Webra would be the stronger of the group if your after speed.Depends on the prop.I've found out that the same engine can do a lot of different things by changing the prop.
I"ve had four Shrikes,all 40 size and the 40 size will fly nicely with a 25,so it don't take a power house to move it.If it's your first speed plane,I wouldn't over do it.Get used to the handling and go from there.They're a different little animal but a lotta fun.
Keep us posted
Walt
Keep us posted
Walt
TX
Howdy,
The Shrike 10 is a good first speed plane. The .25 will really make it go. With the Webra you might have to add some tail weight.
Some mods you might want to consider if you use anything above a .15 are: Move the firewall back a quarter inch, Use hardwood spars in the wing, & sheet the entire wing and tail area. Also you might want to add some balsa to the inside of the trailing edge to give the hinges something to grab.
The firewall mod is to help in balancing the heavier engine, when using a .25 and putting the battery as far back as possible no additional weight is required. The other mods are to keep the plane in one piece.
Enjoy,
Joe
Enjoy,
Joe
as strykaas mentioned, here I am.
here are the mods I suggest if you are going with a .30 size engine
-replace the balsa wing spars by spruce spars
-enlarge the wing sheeting
-sheet the stab
- sheet the fins one side
-move firewall backward 1/2 inche
-extra hatch in the back of the fuse for battery pack
-builded canopyless to reduce the drag
mine flown something like 140MPH. My neveuw overstressed the airframe during extreme hig speed manoeuvre and this resulted in a wing failure in flight......
this was a great flyer
-sheet the stab
IL
I did most of the same mods that Salmonbug did to his. After going to the .32, I won't go back to the .25. I actually like my Shrike better then my JETT FIRE powered Diamond Dust. Beefing up the wing is definitely needed. I ripped the wing off my first .32 powered one. Good Luck. [link=http://www.911teletrainer.com/craig/shrike4.htm]Craig's Shrike[/link]
Hi,
Thanks for all the good info; I decided to "Go for the Gold"!![X(] Just got a new Webra .32 for the Shrike, will use standard muffler and maybe a 10x4 prop to begin with.
I will certainly follow your suggestions for strengthing airframe--had already decided to replace balsa spars with spruce; will add sheeting to other areas, too.
Thanks, again.
Thanks, again.
Which Webra did u choose : ABN or ringed ?
Keep us posted as you move forward !
Hi Strykaas,
My LHS had a NIB Webra 32 ABN for $75.00 that I couldn't pass up--would probably have gotten ring version if available. Also looked at MVVS 28. My previous experience with Webra helped me decide--I know Webras; I'm sure MVVS would be fine but don't have any experience with them--yet.
I had a Shrike 10 with MVVS 28 in it...you can turn the cylinders on those to rear-exhaust and use a rear tuned-pipe. Only before they are broken in though! I turned mine to rear exhaust for less drag. (looks cooler too[8D]) Turned an 8x7 at over 15,500 as I recall. Moved right along with that engine...much faster than the OS 25FP I had in it before that...hehe. I had nothing but great experiences with my MVVS's..I also had the GRRT pylon engine in a Diamond Dust, which is a good step after the MVVS 28-powered shrike if you still crave speed.
No experience with Webra's, sorry!
Carl
Carl
TX
I'm not famailiar with the Webra engines but have always been tempted to try one.I am famailiar with the MVVS"s. I have a 49 and a 40,both power houses that like to turn hi rpm's. I'd recommend them to anyone..I'm running a 9X9 on the 49 and it really gets it.
Later
Walt
Later
Walt
CA
Hey folks....I'm thinking about glassing my shrike .10. I have an 0s25fx for power. Any suggestions as to thickness of the cloth to be used??? Hopefully it wont slow it down too much....whadaya think???
