Chuck Auger Prop selection
DE,
From my reading you seem like the guy to ask so here goes.
I have a sonic 500 from hobby people. Its a basic quickee 500 no vtail type plane. Yesterday I broke in a new OS 46 ax with a 10x6 and at theend of the first tank I was getting 15.5 k rpms. Oh it also has a tower muffler on it. Then I put an 9x8.5 on it and she moved pretty good. It reminded me of my wiplash for a second.
What prop will yield the highest speed and if not readily available can you make me one please. Glad to pay you for your time.
Regards Robert Sando
Anyone else with valuable info feel free to post.
MN
RE: Chuck Auger Prop selection
We race that engine on the same type of planes. APC makes several props that work well.
8.8" x 8.75
8.75" x 9 W
These two definately work well and are available from either APC or you can get them at www.pspec.com
8.8" x 8.75
8.75" x 9 W
My Feedback: (12)
Yeah, don't get me to lying!! The props I modify are for a lot larger engines. There are plenty of off the shelf props for engines in your size range. The only reason I even started modifying props was because there are no commercially available props in the size/pitch I wanted to try.
For this size engine, I would highly recommend that you follow daven's suggestions..he has LOADS more experience on the .46 sized engines on planes similar to yours.
Just for reference, we are turning the 8 3/4" x 9 W on that engine at roughly 16,300 RPM.
WOW, if that engine unloads any in the air your busting right thru 150 MPH+.
Thats honking[X(]
Cajun[8D]
DE,
Well I am gonna order some 9w's. My 9X9 was turning 15k today and it was grooving pretty good. I guess when i get the 9w's I can compare.
thanks again for the help.
this sonic is a fun little aiplane to fly but Damn is it hard to land
any tips on landing it?
