pusher V tail project
IN
RE: pusher V tail project
here are some shots of my engine. trusty 46 fx that i modified by increasing the port timing, crank timing, and boring the carb out to .375". Made the header from 5/8 thin wall tubing. The tuned pipe will be in the fuselage. I did a quick test run yesterday and got 13,400 on a 9x9 apc, 10% nitro, a crappy tune, and open header with rubber hose attached to the end (to send exhaust outside the shed, can see in the pic.)
IN
I am using autocad. I plan to lay up the fiberglass over foam for the fuselage, and have not decided how to make the booms yet. Maybe built up?? We'll see.
