T-38 (.40 to .50) size...........
#53
My Feedback: (40)
NJ
RE: T-38 (.40 to .50) size...........
If you want one, please leave me you E-mail at [email protected].
Its going to take a while OK.............
My Feedback: (50)
OK Angel, put me on the wait list for an ARF or ARC T-38 (50 size) The longer the wait the better, I still need a job! [X(]
Angel would you be willing to cover one up for me when the time comes and obviously I will pay extra? Just a thought as I am totally intimidated by the Blue Angels scheme but always wanted one done well!
I know you are busy, if it takes a year I still want one! You are what the hobby is all about Angel --- That T-38 is the nicest prop-jet I have seen, even nicer than my Patriots! (OUCH)
#55
My Feedback: (24)
Just tried to send you an e-mail and it was rejected:
Hi. This is the qmail-send program at yahoo.com.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<[email protected]>:
167.206.4.79 does not like recipient.
Remote host said: 550 5.1.1 unknown or illegal alias: [email protected]
Giving up on 167.206.4.79.
#59
Cool jet man !
I've been convinced by countless sources to make my jet a Prop jet... I am building an F22. 36 by 27 wing span. What engine size are you using? What engine size / prop should I use if my plane weighs around 3-5 pounds ? Should I push or pull?
How did you shape the foam like that when you made the wings?
-D
-D
#60
My Feedback: (40)
NJ
Well I started with foam block , Cut out the Root & wingspan, Then make your template to a desire airfoil. one on the wingtip & Root. Use a Hot wire to cut the foam. Have a steady hand . Try a few piece first.
#61
My Feedback: (40)
NJ
Thats a small plane there , .25 to .36 with a 8X6 or something around that range, and depends on the Eng. I would put the eng. in the front. Good luck !
#62
My Feedback: (40)
NJ
Hello REVVERS and MEMBERS
I just want you to know that I will be starting on the T-38. After the holidays.
I still have the RIFLE upon request.
Angel
Angel
#69
Hey Angel,
Well, it's after the holidays, you better get cracking!
A couple of questions:
1) Are you still on schedule for the Febuary(ish) release of short kits?
2) Is it practical to handlaunch this thing and avoid dealing with retract gear issues?
Mark
Mark
#71
My Feedback: (40)
NJ
Hey I want to see that too. I hope you have a Rossi 105 or something.
Yes ., I'm cracking up[sm=what_smile.gif] of all the work.
There is no way you are going to throw that big plane.
This is almost the size of TopGun F-15.
#72
ORIGINAL: Razor-RCU
Hand launch a 90 sized propjet.? WOW
Maybe Nolan Ryan could do it?
No, no, no. I'm not that crazy. I was talking about the 40 sized version....But I like the way you think.
Anyhow, what are the chances with the little one? I just don't want to deal with retracts and a thin wing on my field, if I can get away with belly landing it and no gear. I was thinking of a similar launch technique to the deltas (DD, Outlaw, etc.) where you let the power drag it out of your hand at about a 45 degree angle. Would that work or not? It doesn't have the wing area that the deltas do and it will be heavier, so I know it's more marginal. The more I think of it, the better retracts are sounding...
Mark
