(Something Fast?) Delta Build Thread
#201
RE: (Something Fast?) Delta Build Thread
ORIGINAL: Speedy-Gonzales
I am not going to glass my center section either. Mainly because I will have the advantage of a fully sheeted wing.
#203
Just have never had that good of luck getting iron-on coverings to stick to fiberglass cloth and resin. I suppose I could install a skid runner on the bottom. ChuckL....what did you do?
#205
I use a product called Stix-It made by SIG. It is heat activated glue and adhesion enhancement. It's brushed on all the surfaces that the Ultra Coat will contact. Works well on fiberglass, epoxy, plastic and of course wood. Brush it on in one coat quickly and thinly but well covered. If you get lumps or little bubbles you need to change your technique. It can be thinned just bit if you must with Sig Butyrate dope thinner. Best results are when applied in temps under 80 degrees. Let it dry to the touch before you try to cover in about an hour. It seems to work many days after it's been applied so there's no rush. You can sand it if you must with some loss of function once it's dried a few days, just don't make friction heat. Do test RUNS first. Do this out side or where you can get away from the fumes. The covering can be removed with the use of a heat gun but it ain't fun nor pretty.
This stuff is great to put back down loose covering! Pull back the loose covering and wipe clean with paper towel dampened with denatured alcohol. Be careful not to wipe through to the color. Next wipe the wood side with acetone, you just want to get the oil off the surface not soften the glue that holds the plane together. Don't get the acetone on the covering you could take the color right off fast! Let the wood dry 10 minutes or so before applying Stix-It to the wood side with a brush or Q-tip(s). Don't let it wick into corner where you have the covering pulled back or you will have a lump there later. When dry to the touch, iron down the covering.
Hope this helps
Hope this helps
#206
My Feedback: (202)
The only downside I can see using the STIX-IT is that it adds no rigidity to the airframe where the epoxy or polyester resins will. I coat the area to which you want to apply F/G cloth with a coat of nitrate dope or balsarite first to seal the wood. This is where most guys get such a weight build-up when applying F/G cloth and resin. The balsa is like a sponge when not sealed first and the weight is doubled because half the resin soaks into the wood. Only one coat of sealer is needed with a good sanding when fully dried to remove the "fuzz". I always keep a few pieces of used sandpaper on my bench for this task. Then apply your cloth and resin. Works for me. Give it a try. Speedy
#207
My post was in response to your question. Stix-It is for covering, i.e. Ultra Coat. It helps it stick much better to previously applied F/G cloth, epoxy or other surfaces.
It's not for "glassing."
#208
My Feedback: (202)
Comprende Amigo!!! You apply the Stix-it over the previously applied F/G cloth then put the final covering over the top. Do you think the Stix-it gives better adhesion than Balsarite on balsa or are you advising the Stix-it for application over fiberglass cloth and resin only? I am curious which product is better on just plain balsa too. Regards! Speedy
#210
To use iron on covering over FG has always been trouble for me, the gas bubbles are hard to control. For the FG belly armor on a little delta, I don't care if the covering sticks to it or not. For other FG parts, like fins and cowls.......I just gave up with covering and paint them with Glasskote.
#212
I've got a couple of open framework planes that do about that speed, and the covering hangs in there OK. When it comes to getting coverings to stick to resins, I think resins have a wax film build as they cure? So wiping the cured resin down and sanding it should help the covering stick, also.
#213
OK
here we go...I ordered a kit from mike today.
My first thought is my little 28-40-2500 medusa on 8 cells of 2300 A123 turning a 5.5x4.5 apc if I can get the nose streamlined enough. I am running this setup on 6 cells now with the same prop, so I will have to trim the prop a bit to prevent overload. I have gotten 65 amps from 6 cells with this setup, thats my first thought. just tweak the prop for a target of no more than 80 amps on 8 cells of 2.35 volts under full load. that little motor is a speed 400 by design, but it is simply amazing and doesn't heat. I mount it in a heat sink, and the ESC is in the wind. Its currently installed in a nitro .25 bobcat...the little yellow one that came out this year. It does about 100 with the 5.5x4.5 on 6 cells. I just ran medusa motor calc with 5x4.5 and 8 A123 cells. I think I will experiment with that on my bobcat when the weather clears as a possible elec setup. thats 22ounces of battery plus about 5 ounces of controller and motor. so the motor/radio gear with servos and BEC...about 2 pounds. 1200 watts and 40,000 rpm. Might require hearing protection though for the scream. A 5.25 inch prop maxes out at 44000 rpm, but it sure makes a ton of thrust when the tips are up around .9 mach....
What does the plane/covering comeout to?
#214
ORIGINAL: gooseF22
OK
OK
The last one I built came out to just under one pound for the airframe covered. Make the wing tips thin and a little sanding should keep your weight down. You won't need the fuel proofing either.
There are a couple of people building one for electric but I have not seen any pictures yet. I do have a couple pictures of an electric Dust if you want ideas on how to mount the motor.
#215
ORIGINAL: gooseF22
#216
ORIGINAL: gooseF22
#219
ORIGINAL: Troy-RCU
Sweet! How is that black leading edge during oncoming passes?
Attached are two pics RTF. I did not weigh it yet but I am sure it is close to 2.75 lbs.
Speedy should have his Mutant Demon with a Nelson Q40 engine done soon. Several mods from my design but he can tell you about that.
#220
My Feedback: (202)
It is done! This is my "Mutant Demon". Let's pray for some warm weather. I will need all the feeling in my thumbs to test this bugger out! RTF is 2.9 pounds dry. Nelson Q40 with Perry 5001 carb. 7.4 x 8 APC carbon prop. JR receiver with Hitec HS-225 MG's on elevons and a HS-85 on throttle. #4-40 linkages. Tetra 5.5 oz. bubbless tank. Fully sheeted airframe and Ultracote covering. Hand laid-up fiberglass cowl with internal baffling. I would like to thank Mike Connor for the kit and ChuckL for letting me use his color scheme. Let's go flying!!! Denny Wann / aka "Speedy Gonzales"
Revver Bro #182
Revver Bro #182
#224
My Feedback: (202)
Troy-RCU, Thanks for your blessing on this model. That's right guys. This is where the rubber hits the road. I am a no B/S balls out "speed freak". If I survive the first flight this thing is gonna turn some heads. I have a safety feature incorporated into the model. It is called a throttle! LMAO!!!
