Heat sheild
Old 03-06-2003, 10:29 PM
Cactus.
Cactus.'s Avatar
Default Heat sheild
This is for the magnum im building, i need to protect the glass canopy from the pipe, it gets soft enough stiing on a heater waiting for PAV webbing to dry
forget your expensive turbine sheilds... im talking stuff around the house if possible is tin foil ok? whats best to stick it with.
All susgestions for sheilding are welcome ( freezer paint? )
Old 03-07-2003, 06:28 AM
FlooredCOBRA
Default Heat sheild
maybe try heating and air foil tape. It is sticky on one side and it holds it shape. I used this stuff everyday at work and its pretty strong stuff. Also they have different thicknesses
Old 03-07-2003, 10:44 AM
Cactus.
Cactus.'s Avatar
Default Heat sheild
heating and air tape??
is that for ventilation ducts or something? i don't know where i can get that locally, but i'll keep a look out. thanks
Old 03-07-2003, 10:06 PM
FlooredCOBRA
Default Heat sheild
yeah it is standard foil tape is what they usually call it. you can get it pretty much at any hardware store.
Old 03-08-2003, 01:58 AM
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Default Heat sheild
Maybe this can work for you: http://www.bvmjets.com/Tools/heatshield.htm
Old 03-08-2003, 03:04 AM
Flipper
Default Heat sheild
I would say the foil tape will work you could even put 2 layers. I used it on my fiberglass hood on my snowmobile and the plastic belly pan because the 3 expansion chambers get real hot and I have not had any problems for years.
Old 03-08-2003, 06:23 AM
FlooredCOBRA
Default foil tape
The tape we use is called UL181 and usually has the red writing on it. They make different kinds if yo can try to get the kind with red writing on it. This type has more thickness to it compared to the unmarked Foil tape.
Old 03-08-2003, 11:59 AM
Cactus.
Cactus.'s Avatar
Default Heat sheild
it wont be getting too hot, there will be active air scoops to cool the area, it's just where the pipe gets close i worry a little. will look for vent tape this afteroon sometime.
