60 SIZE PATRIOT
#51
TN
RE: 60 SIZE PATRIOT
Yes SpeedBoy..,, i will post some picks sometime in the morning daylight shows better on a plane,,, i have the wing finished exept for the covering and alerions,,, i am working on the fuse at the moment ,, i can't wait to fly this bird it's going to be a rocket,, probably not as fast as yours []..
#52
RE: 60 SIZE PATRIOT
ORIGINAL: hummingbird111
And maybe your patriot will fly more fast than mine , if your incidences are perfect (that I do not doubt it ) have to help for high speed , between other things of course , once in the air we will see , you will use tuned pipe or stock muffler ???
#53
TN
RE: 60 SIZE PATRIOT
I will use the stock muffler,, i have read somewhere here on RCU- that using a tuned pipe on this engine would not be that much of difference,, so to save weight stock muffler will be fine ,
-------------VAROOOM!!!!------->
#54
RE: 60 SIZE PATRIOT
A guy in the field has a jett .50 tuned pipe 10x6 apc and he say turns at 19,500 rpm , and that was gaining 2,000 rpm compared with stock muffler , I dont know if that is true or no , but anyway I want to tell you that data . Any tips for more speed sound good
Maybe if bob27s see that number can tell us if is possible or no
#55
My Feedback: (19)
OH
RE: 60 SIZE PATRIOT
ORIGINAL: SpeedBoy
a standard SJ-50 engine with the stock (jett-stream) muffler turns a 10x6 around 17,500
with a full size pipe..... maybe pushing 18,000 - but the difference is more a few hundred rpm, not typically a couple of thousand.
Yeah, gaining 2000 rpm is possible on a shorter full-size pipe, but you would have to trade down on prop size to get there.
#56
RE: 60 SIZE PATRIOT
bob27s very thanks for data and your help one more time [sm=thumbs_up.gif] btw very fast response
Now I know 18,000 with 10x6 without cutting.
TN
RE: 60 SIZE PATRIOT
here are a few picks, it seems like the wing is allways the pain in the neck on kit building,, the fuse should be a breeze. HB-111
#58
RE: 60 SIZE PATRIOT
VERY GOOD !!!!!!!!
It seems that in less than 1 month your bird flew by skies
You know what color you are going it to cover yet ???
I keep follow you advance and I waiting the report from the maiden [sm=thumbs_up.gif]
BTW thanks for the pics .
#59
TN
RE: 60 SIZE PATRIOT
I have been thinking hard on the colour scheme but im not too sure,, i wouldn't mind trying the red & white Edwards test colours that's used on the F-16's,, but i also like the F-5 swiss scheme too,..
#61
RE: 60 SIZE PATRIOT
Hey hummingbird , it seems to be very well [sm=thumbs_up.gif]
I have in my computer this pic maybe can help to bottom side or something any desicion that you take will be fine
#62
TN
RE: 60 SIZE PATRIOT
wow!! nice picks SpeedBoy.,, i like the thunderbird look on the bottom,, i might try that on the bottom side, and the pick i did on the top,, thanks ,.
#64
TN
RE: 60 SIZE PATRIOT
LOL,, a camera phone just doesn't do justice for a good pick,, here are some more picks. yes the build is slow,, i have been busy around the house with other to-do projects.
#65
My Feedback: (19)
OH
RE: 60 SIZE PATRIOT
word of caution of sorts..... bolt the muffler on.... and make sure it clears the fwd fuselage. You may have to re-contour the bottom radius area to ensure it clears properly. Much easier to do before you apply covering
Bob
#66
TN
RE: 60 SIZE PATRIOT
Thanks bob , i'll try that ,,,yes it's close, i may try some aluminum foil in that area to prevent the covering from melting, i did that on a wing i built once and it worked good, but it looks like i have about 1/4 inch clearance or mabey a little more on this one,[sm=thumbs_up.gif]
#70
RE: 60 SIZE PATRIOT
Very good job there , don't forget to clear the label of the prop
Hey hummingbird , why you don't put a spinner on it , should be a less drag
Congrats for you new speed plane and good luck with the maiden [sm=thumbs_up.gif]
#71
TN
RE: 60 SIZE PATRIOT
SpeedBoy,, i don't have a small enough spinner for the plane at this time,, i will get one ( red ), yes the label on the prop[X(] almost forgot, i just put it on, right before i took the picture,.--->maiden may be either Thursday or sometime after ,,, looks like rain is coming this way [],, Thursday looks like the only day without rain.))))--> I suppose it might help if i put the muffler on too.
-----------VAROOOOM!!!!-------->
#72
TN
RE: 60 SIZE PATRIOT
Just to clarify so no one miss-understands,, the Yellow and black patriot at the beginning is the 60 size,,,,,,,, this Red and White one , is the 40 size Patriot,.
#73
TN
RE: 60 SIZE PATRIOT
I could not help myself..here"s one more pick from today, i finally got around to breaking the SJ 50 in ,, boy !! this little engine is a screamer , i could not believe how the patriot wanted to just JUMP! out of my hands on a 9/ 7 apc prop,.----this is my camera phone ,, please excuse the fuzzyness,,.
#74
RE: 60 SIZE PATRIOT
YEEEE HAAAAA thats sound very good hummingbird , can you feel the adrenaline in your body when you hear the engine screaming ??? heƩ heeƩ[8D]
With that prop I guess is around mmmm...... 17,500 rpm !!!!! maybe more ..... do you tach ??
What about the weather for the maiden ???
#75
TN
RE: 60 SIZE PATRIOT
Yes i have a tach, i was getting around 16500,(( gonna keep it rich for a while )), i was scaired the prop was gonna explode [X(] im' not use to this very high rpm stuff,, the engine runs smooth but wow , very loud,, it's ok ,, i love the power,, oooohhhh yessss!!,,,,,, while breaking it in , i allmost wanted to wear a helment or something hee hee,,----i'm gonna try a maiden this Saturday
-------------VAROOOM!!!!----->
