West .50V1 bench run
#51
RE: West .50V1 bench run
ORIGINAL: combatpigg
This is the first time I heard that the West was all West internally. It's interesting to think that they saw a way to make money off an already popular engine and even doing so with Webra saying, ''OK, here you go, we'll sell you a bunch of cases''
#52
ORIGINAL: Daytona955i
in the instructions of 52V1 is written 1'' ... Alan also told me 1 ''
I read that you use the 9x7 in 50V1 ... How many rpm in static ?
do you have cut manifold ?
Marco
ORIGINAL: mk1spitfire
I'm not sure if the 1'' cut applies to the 52v1? But it could do.
Marco
I cant remember rpm on 9x7, Im sure about 18-19.
No, not cut manifold but that doesn't mean you shouldn't as yours may be different length.
I am now running 8x8 without shorter cut manifold.
Its on the pipe.
However I too should fine tune it but have been playing with props,like 8x10,10x6,9x7.
So, I guess it can sound on the pipe but a tacho and not ear can fine tune the rpm on manifold length.
#54
Im sure over 20k with 8x8.
Fuel was prosynth 10% nitro but switched to higher %oil, Again fully synthetic,nice clean engine.
The oil is edl and sical additive by Model technics called pro power
The 9x7 is an excellent starter prop, Very good launches,good all round prop until moving to another
#55
ORIGINAL: MJD
I know the .50 will turn a 9-6 at about 20k. Mine did that with the header trimmed 5/8''.
in addition you also had the open pipe ... is right ?
Marco
#56
I used both pipes.
On my Magnum I used the Weston pipe with the header trimmed 5/8". This is where the 9-6 tachometer number is from.
On the Demon delta I used an open pipe. On that I used an assortment of clipped pylon props. The header has been trimmed to a total of maybe 1" or a hair more.
MJD
MJD
#59
you feel the need ... the need for speed ! [8D]
You are fantastic in your video!
How soon before you maiden yours?
#61
cool !
I've seen that uses 10% syn/cas
is the nitro 10% ?
is the syn high density ?
Marco
cool !
is the nitro 10% ?
Marco
MJD
#62
ORIGINAL: MJD
Regular 10% nitro syn/cas blended oil sport fuel. Wildcat or Omega. I think the synthetic oil in those is classified as high viscosity.
MJD
MJD
Marco.
