Prop Question.
CA
This might not be the best place to ask this question but I didnt know where else to ask.
I need a pusher prop. Either a 2, 3, or 4 blade. Just depends on the pitch but the diameter cant be any larger than 12 in. It will be going on an OS .91 FX engine. I know Master AirScrew makes a few, Graupner has a couple, APC has several too. None of these companies make one in a low diameter (12 in) with a high pitch. I have a ground clearance issue so I am limited in diameter.
Anyone know of a prop company that has a large selection of pusher props?
Charles
Charles
My Feedback: (66)
get the zinger 12x8 wood one and let the engine turn. it wont hurt it at all. The master junks have less than the pitch stated on them compared to other props, but durable. if its turning to high rpm then get the 14x8 and trim it down to 12" and then clean it up and balance. it will have wider blades than the regular 12x8
