MVVS GRRT engine mount...?
1 Attachment(s)
Hello folks,
Does anyone happen to know who makes a suitable engine mount for the GRRT? Preferably in aluminum... The mounting bolt pattern is slightly different to what I'm used to... (see picture) Also, if I don't get a mount that fits like it should, can I just drill an extra hole in each of the rear mounting lugs and just use a standard engine mount? Will that damage the engine when operating at peak power output... or will I just loose some power perhaps...? |
RE: MVVS GRRT engine mount...?
I ended up drilling two holes so it was like a regular set up. The 2 way up front was hard to find mount for. So I went the other route. It didjtn have any effect at all on the engine, works out just fine.
Rudeboy,
Which tuned pipe is this ? You could use a plywood mount instead of drilling these holes ! |
Hi,
Did you receive my email? I have an alu CNC mount for the MVVS rear in stock. Regards, Look. |
can I just drill an extra hole in each of the rear mounting lugs and just use a standard engine mount? |
ORIGINAL: Strykaas Rudeboy, Which tuned pipe is this ? You could use a plywood mount instead of drilling these holes ! Yeah, I could make a plywood mount... hadn't even thought of that... The main reason I asked was because F3D pilots use alu mounts because the engine case doesn't hold up with all that power. I don't know if this is the case with the MVVS, but I know it is with Nelson and MB engines. These last two are more powerful of course. |
ORIGINAL: look Hi, Did you receive my email? I have an alu CNC mount for the MVVS rear in stock. Regards, Look. If I decide on the Stinger I will order the mount too. If I don't get the Stinger I will probably order the mount anyway...:p |
| All times are GMT -8. The time now is 04:24 PM. |
