DF Picco 45 with pipe.
I bought this engine to power a scratchbuilt delta fast. Anyone know the ballpark RPM figure I should be aiming for? I bought a bunch of ASP pylon 40 props 9 x 7.5 and 9 x 8.5 I'm hoping one of these sizes will be suitable for my Delta.
My Delta "Turbine Waiver" is going to use a foam core wing with a SD 7003 airfoil, 23 inch root, 7 inch tips, 450 squares. How big of a fuel tank do you guys use with a setup like this? I never thought there was a forum for this sickness. :D |
I forgot to mention that now I'm flying a 40 Shirke with a Tower Hobbies .40 with a muffled tuned pipe. The plane is good for about 100 mph, and unlimited vertical, the guys at the field think it's fast, boy are they going to be surprised when I bring out "Turbine Waiver". I also bought a OPS .61 with pipe if the Picco 45 isn't fast enough.
Hey Rich!
Glad to hear of a Picco! I have some .40's and .60's..but never have seen a 45 DF.
I think your engine will run those props if you get your pipe set right, but I think (opinion) that you need to drop about 1" diameter to run on a fan engine. I don't think a fan engine will turn either of those props in the RPM range the engine was designed for. My guess for RPM is 17/18K?? I would try to prop for 20K static with at least 8" of pitch...Just my opinion, my engine is an OS...and I like Piccos! The plane sounds great! I run 6 OZ of fuel..4OZ tank with 2OZ header tank. Runs sweet all run long. |
