RCU Forums
-   Extreme Speed Prop Planes (https://www.rcuniverse.com/forum/extreme-speed-prop-planes-104/)
-   -   (engine thread) converted to U/C thread :-) (https://www.rcuniverse.com/forum/extreme-speed-prop-planes-104/1757300-engine-thread-converted-u-c-thread.html)
Dave03B 04-25-2004 03:29 PM
Rossi .60 piped vs. MDS 58 what do you think? which one?
The rossi is heavier than the MDS i think...... but will haul even more @$$! i could put the nicad right at the very back of the tail and dont mind adding a little lead.......
What do you think?
Cheers all.
Razor-RCU 04-25-2004 06:00 PM
RE: (Patriot) Rossi .60 piped vs. MDS 58 (could be piped)
I bet a Jett-90 is similar, if not lighter, than the Rossi- Of course "run what you've got" :D If you have the Rossi...
There is a Jett-50 out on the hillside somewhere at my club if you need one--:(
Dave03B 04-26-2004 01:28 AM
I''l be over in a few hours to look for the jett:)
cheers
bob27s 04-26-2004 01:16 PM
Razor... sorry to hear about the flyaway! Have someone fly overhead in a full size and look for the glint of gleaming aluminum :)
Either of the engines, if you already have them, will run pretty well...... but put a Jett-Stream muffler on them instead of the full pipe. Its only about a 500 rpm difference (in most cases) and its not as critical on prop selection. Will tend to weigh less than a full header and pipe too.
I bolted at jett-stream on a friends Morris 45 (rossi) saturday. He had all sorts of problems...it had decent top end, but wouldnt idle or transition....he changed the carbs... all sorts of stuff. It appeared that his 'stock' exhaust system was leaking pretty badly around the o-ring.... was rarely consistant on performance..... it was hard to get a consistant needle setting....and if I recall that muffler is 'tuned' to run around 17K rpm....so it ran like it was overly 'short' causing the midrange and transition problems. I had a rossi adapter in my field box, so I took the muffler off of my SJ-50, and installed it on his 45. With the jett-stream it idled down nicely, needled great, and gnerally behaved very well....... plus had 15K on the top end with a 10x7. Not too bad. We did note that it ran 300 rpms less with the same prop.... on the ground. It definately unloaded better in the air.
Dave03B 04-28-2004 02:41 AM
INSTEAD OF RETRACTS??
Been toying with the idea of a simple take off dolly for my patriot. Save retract weight + the work of putting them in.
Thinking wire frame, trike, two, maybe three rods going up into the fuz to hold for when on the ground, but on roll out, the dolly slips out of the fuz.
What do you think? and pics of a suitable dolly would be great.
Cheers
