Prop selection help please
1 Attachment(s)
i need your guys help i have a sig kobra with a 32sx with tuned pipe and i am in desprite need to know what is the best size prop
to use to get max mph thanks |
RE: Prop selection help please
The 32 SX works well on a smaller airframe with an APC 8 x 7.
For your plane - try an APC 9 x 6. Or a Bolly 9.5 x 6. Good luck. |
1 Attachment(s)
i used a OS32 (with a heli pipe) on a US40 and achieved max speed with an APC 9x7, took allot of runway to get airborne but top speed was clocked with a hand held at 104mph.
kc |
Nice little Kobra :) prop selection has everything to do with how you pipe is set up. What prop are you using now? What rpm? What is the pipe length set at ? In general (without knowing the above info), the OS 32 likes rpm. I'd tend to work with an 8x7, 8x8, 9x6, and maybe even try the APC 8.5 x 7.25 q-500 prop - all depends on how the plane resonds to it. Bob |
| All times are GMT -8. The time now is 07:55 AM. |
