3G issues
i know the 3G isn't perfect but i'm running 3.0 software, 2100 RPMheadspeed Trex 600Nand am wondering if theres a fix to this issue im having. my elev gain is all wack. so if i turn it down from where i'm at now, during a forward flip from a standstil into forward flight, the thing shakes like heck on all axis!if i raise the gain, it doesn't shake anymore during a forward flip, but when i'm moving forward and pitched forward and try to pitch pump it the elevator wobbles up and down. it i turn the gain down it doesn't wobbly like that anymore but does that wierd forward flip thing. any suggestions besides getting a BeastX?
Thank in advance!
Thank in advance!
Hey my friend, Sounds like you have a vibration problem, Try a pad then a metal pad and then another foam pad also make sure the wires are snapped in all the way. I have a 3g on a 600E and it is flawless...so far. You may try to go through your head set up again and make sure there is no binding in the extreme throws. Make sure there is NO trim or sub trim,
JIm
JIm
