Go Back  RCU Forums > RC Helicopters > Flybarless Helicopters
Reload this Page >
Tail Kicks BeastX
Flybarless Helicopters Discuss flybarless rotor head systems for all helicopters right here.
Tail Kicks BeastX
Old 09-23-2020, 08:57 AM
Big Windy
Question Tail Kicks BeastX
I have an AR7200 just installed on my Gasser and the tail Kicks hard/rapidly and returns every 20 to 45 seconds. I can feel nothing unusual in the gear train or on the servo. The servo is a new Spektrum Tail servo.
Any thoughts on where to go or how to solve the kick?
Old 09-23-2020, 10:13 AM
A. J. Clark
A. J. Clark's Avatar
Is your motor running smoothly? Bearings all in good condition? One way ok? Clutch holding good? All of these cause a kick on the tail.
Old 09-23-2020, 02:07 PM
Big Windy
All seems well. The One way appears fine, but I will lube it as it has been sitting for more than a year. A bearing seem smooth and everything swings easy with no drag or noise.
Thx for the one way thought!
Old 09-23-2020, 02:09 PM
Big Windy
Should have also said I overhauled the carb and it seems smooth and easy starting.
Old 09-23-2020, 04:16 PM
A. J. Clark
Another thought is if the control rod to the rudder is to far out on the servo horn can cause problems.
Old 12-21-2021, 08:47 PM
dwad
remove the thrust bearings and check and re-grease.
