propelers wont spin and keep twitching
i have a catiliena seaplane that wont take off because the propelers wont spin. some times one will spin fine but the other one wont. any sudgestions on how to fix this?
TN
RE: propelers wont spin and keep twitching
Does this have twin brushless motors off one ESC? Usually you need one ESC per brushless motor.
But check all connections too.
If it is the cheap Nitroplanes model, you need to make sure that the battery is fully charged. Also, to be sure, charge the battery again. If is is almost dead, you can damage the pack if you over discharge it.
