Techone Apollo Mini Milled Plane available at 2dogrc.com
NC
The Ultimate in Indoor Flying!
Following in a tradition of great foamies, Techone released the Min-Apollo. This plane is 27" and more pattern focused. The factory used advanced milling techniques to reduce as much weight as possible, without losing too much strength of the plane. This plane can be built at under 105-125g and will float in the smallest of gyms!
If you search the net you will see that many places charge of $80 for a milled foamy, and that is not including all the pre-printed graphics. A milled airplane is what every ETOC pilot flies with, and you will be amazed at the difference a few oz or even grams makes! You never know until you try!
These will be arriving around Nov 9th and we are offering $10 off any preorders! We also have combos on the website. If you buy a combo with all Dualsky parts, the motor, ESC, and Battery have connectors already attached. That means connecting the electronics takes 5 min!
[link]http://2dogrc.com/product/techone-mini-apollo-3dpattern-27-milled-foamie[/link]Available here!
Wingspan: 700mm (27.5in)
Fuselage length: 750mm (29.5in)
Flying weight: 105-125g
Motor: Dualsky 2215-17
Propeller: GWS 7035..8043
ESC: Dualsky 6A
Battery: Dualsky 7.4V 250 MAH lipo
Servo: 4g (or less and 3 pcs)
ESC: Dualsky 6A
OH
RE: Techone Apollo Mini Milled Plane available at 2dogrc.com
just put my order in and it looks like its shipping! I'm flying your Dualsky 31" Yak and having a great time indoors. It flys like
its on rails and I hope the Apollo is the same. Thanks!
OR
Where is your C/G, measured from the firewall? Their description of the C/G location, back from the leading edge of the wing, seems a mite ambiguous!
Thank you!
Chris Shaker
Thank you!
Chris Shaker
