foam glue and options
Let me start by apologizing. I imagine that this question has been asked a few hundred times, but I'm on the road away from my computer today and I need this info ASAP.
I came to have possession of a 3D foamy similar to the ones from E-Foamy and other companies. The aircraft needs some TLC as it has some tears. I understand that the best glue is Welders Contact Cement, but for some reason, none of the hardware stores in this area stocks it. Could anybody please provide suitable substitutions for the contact cement? We have an event coming up this weekend and I would like to bring the plane to the event. Of course, this timeline negates online ordering.
Thanks in advance
Rafael
Thanks in advance
Rafael
GA
RE: foam glue and options
I have....
just giving you options as to what works best.
not posted by me, but this was posted in your thread on the other site..
Theres is no substitute for Welders, maybe UHU Por, but I prefer Welders. Loews will be the only local store to carry it.
I assume you aircraft is EPP?
I'm sure you can find a substitute... but why not use the proper stuff so the airframe works they way it is designed?
TN
i went to my local lowes to get some glue, and they told me it is no longer a stock item. now i am also looking for a substitute glue for hinges.
ORIGINAL: kitman09
http://www.filadelfosrc.com/index.ph...atid=42&id=146
Hi Guys,
Try the new and improved Foam-Tac good for everything on foam airplanes, assembly, motor mounts, hinges etc etc one glue does it all. Low odor so you can build without stinking up your shop, dries fast stay flexible won't yellow you can paint it and a 2 oz bottle is enough to build about 4 medium sized foamies. Awesome glue.
Eric G
Eric G
My Feedback: (15)
I use RC56 Canopy glue on all of my EPP and depron foamies. I have used everything from Welders to epoxy to hot glue. I use it to glue plastic hinges into depron and EPP. I don't use CA hinges anymore on my smaller planes because the ca hinge becomes too stiff for such small applications. I either use pinned hinges or clear tape.
Kurt
Kurt
Loctite Power Grab works great on Foam.
http://www.loctiteproducts.com/p/pg_...ssure-Pack.htm
[youtube]http://www.youtube.com/watch?v=rnOegaOKu38[/youtube]
