Douglas A-1 Skyraider (H-King 800mm with ORX stabiliser)
Takes a few minutes to assemble. Connect up your receiver. Charge a 3S800 pack and you are ready to go. Flight stabilisation system supports Beginner (no inverted) and Expert (stabilised only) modes. Low stall speed enabled me to fly it in quite a tight circuit and inverted flight was stable.
http://www.youtube.com/watch?v=VYF6ZVXTsFg
H-King A-1 Skyraider 800mm - Replacement Propeller Blades
OK now that I have this plane WHERE do I get H-King A-1 Skyraider 800mm - Replacement Propeller Blades???Planes without repair parts are useless
Replacement Prop Blades
If you need replacement blades for your HK A-1 800mm try Banana Hobby they have blades and hubs for your model. They are a direct replacement but without the painted tips, I've used them on my A-1 without issue. I tried to send you the URL but this forum will not permit it until I have 10 posts. I hope this helps.
