EPP foam at 0.9 lb/sqft
RE: EPP foam at 0.9 lb/sqft
http://www.polyform.com/en/buns/epp.html
Let us know when you get some - we might ant to buy a bit of it
Brad in Canada
Brad in Canada
Steve,
Details please... What kind of sizes are available? Min..Max order...Shipping from where?
I have never put the wire to EPP...just EPS and was wondering how it cuts in comparison.
Would you recommend this stuff for a flying wing with a 48 inch or more span?
If so would a single wrapped carbon spar be adequate, or what.
How can I place an order?
Please respond to [email protected]
Thanks in advance,
Rich
Thanks in advance,
Rich
EPP 1.0 $9.99 + shipping for 36"x24"x2"
Use a little higher heat to cut EPP 1.0 vs. EPS but does not need as much heat as 1.3 EPP.
[email protected]
[email protected]
Could you cut it into 3/8" sheets? I would pay 15.00 for 5 3/8" sheets of 1.0 density EPP-I just bought bunch of 1.3 density EPP, even though it will probbably be too heavy for what I am trying to biuld.
$15 plus shipping.
Please check for best rate at ups.com and usps.com from 92069 to your zip code at the dimensions from above.
I will work on figuring out rates shortly.
Steve
Steve
