battery hold downs
battery hold downs
I am building a 3d foam airplane. Is it necessary to use plastic ties on the battery and receiver or will the velcro be sufficient to hold things in place. thanks 85236
My Feedback: (24)
MO
RE: battery hold downs
I use velcro from Walmart. Foamy 3DX with 8 cell 2/3A battery pack. Battery is under wing with one piece of velcro on battery and other on fuselage. No "straps" just flat velcro. I also put a small strip of velcro on battery pack to hold ESC in place. Receiver is velcroed also. No problems even with aerobatics.
Bill
Bill
My Feedback: (18)
All the ones ive seen are just velcro'd. If your using li-po packs It "might" be a good idea to use a tie strap on it to prevent it from getting thrown from the plane and possibly damaged.
IF your flying above grass I wouldnt worry about it, but if youll be flying inside a gym or outside on hard surfaces (a parking lot for example) you might want to add the tie strap to the battery pack just in case.
You could get a long, thin strip of Velcro and epoxy the center of the strip to the plane. Then place the pack on the strip, and join the ends over the pack like a seat-belt. Make sure the ends overlap by an inch or so. Best of both worlds. You get more security, but you can still remove the battery without replacing plastic ties...
Steve
Steve
