Foamies! - RC Electric Foam Aircraft Discuss rc foamie electrics here (i.e. Zagi, Tazz, ProJeti, wingo)
Warped foam/Depron
Old 04-15-2006, 11:18 AM
nitro wing
Default Warped foam/Depron
I bought an Ultrafly Ultimate.The rudder and fin are not flat.I tried to take out the warp overnight with some weight,no results.Any tricks on how to straighten this piece?
Old 04-16-2006, 01:38 PM
spec36
spec36's Avatar
Default RE: Warped foam/Depron
i use packing tape . over bend it the other way and tape from the other side than flip it over and tape it might take a few trys to get it right but it works for me hope this helps[img][/img][img][/img] edit I know this is not the same but the same thing should work.
ID:	446184   Click image for larger version
ID:	446185   Click image for larger version
ID:	446186   Click image for larger version
Old 04-17-2006, 06:40 AM
Glacier Girl
Glacier Girl's Avatar
Also try heat. Hot air or hot water. I use heat to bend depron all the time, so you could use it to straighten out the depron just as easily.
Try the hot water first, soak the depron in it for a couple of minutes, then clamp it straight.
Old 04-21-2006, 12:37 AM
nitro wing
Thanks guys!
The packing tape will probably work
I tried heat to no avail,hot water is something I havent tried.The piece I was referring to was the fin and rudder.Once I cut the two apart and hinged and applied decals,they came out reasonably straight.
