zagi 400x,combatwing xe2,unicornwing?
KY
I was set on getting the Zagi, but then after reading many posts alot of people say that the combatwing xe2 is hands down better. After reading many posts about combatwing then came across the unicornwing. I am very confused and need suggestions from ppl who have these on which is the best.
What do you want to do?
Fly Fast, Aerobatic, Slope, Put around, combat?
For Speed i would get the Mini Speed Wing, Projeti
For Combat i would get the Combat Wing, Zagi
If you have more info on how you want to fly, we can help out alot better.
Then you can't go wrong with these!
Check out the clips here:
http://www.combatwings.com/video_clips.htm
Purchase here:
Purchase here:
I think you'll be better off with the Unicorn - excellent handling stability over a wider speed range than the Zagi, more abust resistant, much quieter, better flight duration.
That's not to say that the Combatwing is bad, I just don't have one to compare directly. I do, however, have experience with the Zagi and the Unicorn. My Zagi's been thru some interesting landings, so I can't sell it. But it gets a lot less air time compared to the Unicorn.
Mark has a very active thead on another active r/c forum, with excellent first flight reports from relative newbies to experienced folks.
GA
Check out the Windrider products at http://www.atlantahobby.com
