Why is this appearing? error dia. Info
Error Diagnostic Information
ODBC Error Code = IM002 (Data source not found and no default driver specified)
[Microsoft][ODBC Driver Manager] Data source 'ASPFORUMDEV' not found and no default driver specified
Hint: In order to use ODBC data sources with Cold Fusion you must create the data source using the Data Sources page of the Cold Fusion Administrator. In addition, if you are running under Windows NT you must make sure that the Data Source is created as a System DSN in order for it to be available to ColdFusion.
SQL = "select marketid from pgd_forums where forumid = 239"
Data Source = "ASPFORUMDEV"
The error occurred while processing an element with a general identifier of (CFQUERY), occupying document position (7:1) to (7:47) in the template file D:\rcu\forum\featured-auction.cfm.
Date/Time: 11/19/03 16:30:34
Browser: Mozilla/4.0 (compatible; MSIE 6.0; Windows 98)
Remote Address: 148.233.96.204
HTTP Referrer: http://www.rcuniverse.com/forum/foru...smode_1/tt.htm
Query String: forumid=239
