Forum questions or problems Post any questions about how to use the forum or any bugs/problems you may be having in this forum.
Java Script Errors
Old 02-20-2004 | 06:50 PM
turl's Avatar
Default Java Script Errors
Is it just me or is anybody else getting Java Script errors when viewing this forum?
Been happening for 2 or 3 days now and I can't seem to solve it.
Any ideas? []
Old 02-20-2004 | 07:21 PM
Default RE: Java Script Errors
What os are you running and what version and type of browser are you viewing this site with?
Old 02-21-2004 | 05:12 AM
turl's Avatar
Win2k Pro.
IE5 ( My firewall doesn't like IE6)
This is the only forum it happens on so I just wondered if anyone else had the problem before before I start to hunt around for the answer.
Old 02-21-2004 | 10:16 AM
not having ie6 and the latest service pack is worse then not having a firewall... personnaly i would update..
Old 02-21-2004 | 11:30 AM
turl's Avatar
OK fixed it - it was because pop up ad blocking was switched on in my firewall settings.
Weird though it's only this forum that causes the error and its always been switched on in the past??
Thanks anyway scimitar. [8D]
Old 02-21-2004 | 02:41 PM
np man.... but again- i would see if you can get your firewall to work with ie 6- because if you dont install it- your going to be missing alot of patches- and can be an open target on a lot of sites... either way- glad to hear you found the problem....
Cheers!
