Go Back  RCU Forums > RC Universe Support > Forum questions or problems
 ''My Forums'' problem... >
Forum questions or problems Post any questions about how to use the forum or any bugs/problems you may be having in this forum.
Old 12-11-2004 | 03:58 PM
SAP_2000's Avatar
Default ''My Forums'' problem...
Since yesterday, when I press the ''my forums'' button I only get 'HTTP 500 - internal server error'
I have been to the 'settings' menu and saved 'my forums' again several times and I get the 'settings saved succesfully' message, but afterwards, when I press the ''my forums'' button I still only get the 'HTTP 500' message.
Again... Everything was working great until yesterday....
Old 12-13-2004 | 11:17 AM
Banned
Default RE: ''My Forums'' problem...
something got corrupt. I did see the bug when I logged in as you and sent it to the developer to work on. To fix it though I simply deselected all your chosen forums. submitted that so there were no forums selected. then went back in and selected all the forums again. This must have cleared a bad entry and now the error is gone but you will need to deselect all the forums then choose the ones you want again. Hopefully we will track down why this occured but this shoudl have you fixed up in the meantime
Old 12-13-2004 | 02:57 PM
SAP_2000's Avatar
Thanks Marc!
But the Problem is still there.
It works if I select all the forums, but if I select the forums I want: ''crash pictures'', ''jets'', ''full scale boats and airplanes'' and ''test posting furum'', I still get the 'HTTP 500 error message....
If I select 'all furums', it works again...
Strange...?
Old 12-13-2004 | 05:16 PM
Banned
try not selecting one of the forums at a time. I am thinking maybe one forum it is choking on for some reason. If you find which one it may expedite the bug tracking. try also to select maybe all the airplane forums by clicking the parent checkbox then submitting just to see if that works. I think we can narrow this down quickly.
Old 12-13-2004 | 06:14 PM
SAP_2000's Avatar
Now it works!
It is either the ''Boats - Full scale'' or ''Airplanes - full scale'' forums that is causing the problems.
Old 12-14-2004 | 03:46 PM
Banned
good clue. I will have my programmer test this and we should be able to locate the gremlin!
