Go Back  RCU Forums > RC Universe Support > Forum questions or problems
 Post indicator -WHEN???? >
Forum questions or problems Post any questions about how to use the forum or any bugs/problems you may be having in this forum.
Old 01-04-2005 | 06:16 PM
Default Post indicator -WHEN????
I must have asked this question about 6 months ago and got the usual "soon" answer. When is there going to be some sort of indicator at the front of a posting in the forums that will indicate that you have contributed to a particular posting?
Why is this so hard to implement?? Ezone and other forums have always had an indicator that shows when you have replied to a particular post. Why is this so difficult for RCU to do?
Old 01-04-2005 | 09:08 PM
Banned
Default RE: Post indicator -WHEN????
We use a slightly different implementation for speed. You will notice some of the other forums are choking and slowing under load now. Some of the code they use was not built for very large forums that are as active as we are and thus don't need to be as conscious of speed. The ones that are busy tend to slow during active periods from inefficiencies. This software was designed to avoid slowdowns and implements a few things slightly different.
ANSWER: What we have to accomplish your request (this is a new feature) is at the top right of the forums you will see the word FILTER. Next to it colored in gold you will see the words on a dropdown select that says "Show all messages". If you select from the dropdown menu "Show threads I contributed to" that will show you all threads that you posted in.
