Java Script Error:
The last couple of weeks I have been getting a "Java Script Error" screen popping up when I go from the home page to the "Topic Page" and then when I click on a topic to go to the posts the "Java Script Error" comes up. I click on the "OK" button and the "error" window goes away and the post page comes up. Same thing happens when I go back to the "Topic Page". Everything functions as it should otherwise.
The Java Script Error:
Description: Function expected
Source: http/::www.rcuniverse.com/.....
line: (gives a number different each time)
See more details?
OK Cancel
click on OK and it proceeds to the next page as it normally would.
I have checked and rechecked my configuration settings and can't seem to find any problem that would cause this. It only happens when I am in the RCUniverse forums. I does not occur with any other forums I check into. Nor with any other website.
I am writing to you as a last resort to see if maybe you might have any suggestions I might try since it only happens with this website.
Please reply via my email address: [email protected]
See more details?
OK Cancel
