Forum questions or problems Post any questions about how to use the forum or any bugs/problems you may be having in this forum.
cant veiw forums
Old 09-08-2007 | 10:02 PM
turbotb0205's Avatar
My Feedback: (31)
Default cant veiw forums
im posting for a friend.. hes a large post# user.. just tonight he told me the forums were down.. i checked.. worked fine for me but hes getting error messages and cannot be found when he clicks the forums.. but not the rest of the site.. i dont see him being banned.. anyone know how to solve it?
already restarted.. cleared cookies reset router modem all that..
this is the error message
"taken from msn"
The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
says:
Cannot find CFML template for custom tag bodycontent.
TEX says:
ColdFusion attempted looking in the tree of installed custom tags but did not find a custom tag with this name. If you are using per-application custom tag mappings, ensure that per-application settings are enabled by the administrator
Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; IEMB3; IEMB3)
Old 09-09-2007 | 06:00 AM
Default RE: cant veiw forums
Had the same 404 error displayed last night but seems to be working now.
Maybe RCU had the forums down for maintenance ... ??
Old 09-09-2007 | 08:44 AM
I had the same problem last night. Tried to visit the forums earlier the morning, same problem. Obviously there was some type of problem as I'm able to visit the forums again.
Old 09-09-2007 | 10:41 AM
My Feedback: (325)
Mine works ok right now. I could visit market and other areas, but not forums (2 different pc) yet 2 of my freinds had no trouble and people were posting all along. I was told to try firefox, but it's too late. It works now with maxthon (IE)
Old 09-09-2007 | 09:22 PM
Banned
we had small issue on our 5th new server which was fixed this AM.
if you see any other bugs going forward please post a new thread here in support forum and I'll investigate and fix asap. I do expect a couple gremlins when adding any new server.
please include as much detail as you can if you get an error including copying all error messages
Old 09-10-2007 | 04:31 AM
Tigger N. Bennie's Avatar
I've had the same problem when trying to log in and the only way I was able to log in to post this message was by clicking your profile and trying to email you--for some reason, I was then able to log in.
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
ColdFusion attempted looking in the tree of installed custom tags but did not find a custom tag with this name. If you are using per-application custom tag mappings, ensure that per-application settings are enabled by the administrator.
Resources:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debug Output Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 1.1.4322; .NET CLR 2.0.50727)
Remote Address 70.173.53.94
Referrer http://www.rcuniverse.com/forum/m_63...tm.htm#6348022
Date/Time 10-Sep-07 05:32 AM
Old 09-10-2007 | 09:17 PM
Banned
any problems now? I think I have fixed almost all the bugs on the new server. we now have 5 front end servers load balanced for rcu!
Old 09-10-2007 | 09:57 PM
My Feedback: (325)
I've been on a lot today and no troubles.
I don;t know what that means, but I'm impressed. Good work (as usual)
