Balsa Plane Builders
Hello everyone I need to find a Telemaster 40 wing I believe the wing is 73 inches long and the middle of wing is 11-7/8 it sits on the plane body 4 inches wide X 11-7/8 long would some make me a Wing??
Telemaster wing
One suggestion would be to check with Mark at Carolina Custom Kits. He has various size Telemasters that he custom cuts. Perhaps you could work something out with him. Good luck, the Telemaster is an awesome plane.
Have you tried reaching out to hobbyist forums or groups dedicated to RC planes? Those communities are usually super helpful and might have someone who can either make the wing for you or guide you on where to find one. Additionally, checking with local hobby shops or online marketplaces could turn up some leads. If all else fails, custom building one, if you have the skills or know someone who does, could be a solution. Remember to share the specs clearly to ensure a perfect fit.
