Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
12fg models to 8fg models.
Old 09-21-2010 | 02:09 PM
Default 12fg models to 8fg models.
Hi,This might sound a very stupid question but i will try it anyway!
I have a 12fg and have recently bought an 8fg for back up and for my power models(12fg used for f3f gliders)
Is it possible to get a model memory(model setup)from the 12fg and using an SD card install it on a 8fg using a data converter?
This would save about 6hrs programming my 8fg for a back up tx on a f3f glider...thanks..fg
Old 09-22-2010 | 03:23 PM
Bax
Default RE: 12fg models to 8fg models.
What you'd like to do just won't work. A model memory in the 12FG just contains too much information for the 8FG to work with. They're not compatible.
Old 09-22-2010 | 03:32 PM
Thanks bax,I suspected this but was still hopefull if in any way a data converter could just copy across the primary mixes in some way to save a lot of time..thanks again
PS could you comment on the possibility that i have heard that the 8fg is telemetry hardware ready and would only require a user SD card update..and that the data port on the 8ch rx would accept a telemetry sender unit...thanks...FG
