Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
Odd mixing issue
Old 10-26-2010 | 11:38 PM
Default Odd mixing issue
Hi there,
I've used a FASST3PMradio with my Ofna Ultra MBX comp for a while now and love it. But recently, I was doing some differential maintenance, and when I put it all back together and went to run it, for some reason, it acts like it's mixxing the signals when I turn left under any velocity at all other than idle or very slow. And it's only when I turn left. I checked my mixing settings and it's all shut off like I want it. No settings were changed at all prior or post diff maintenance. I then reset the radio and went back to redo all my trims and everything. I tried again and still the same result. If I turn left while moving it gives the motor gas and speeds up, regardless of my trigger position unless i'm opening the carb even more than it's already opened by this or braking. I even replaced the batteries in the radio and vehicle. Still the same effect. Any ideas.?
Old 10-27-2010 | 09:09 AM
Default RE: Odd mixing issue
From what you are describing, I would recommend sending this in to be checked out. It could be a number of problems, but it sounds as though it could be a throttle pot issue.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Old 10-27-2010 | 12:57 PM
Is it just a transmitter issue or a reciever issure? </p>
